Re: loose lift mount on 9n leaks like a mother
Posted by Charles(N.C.) on June 01, 2017 at 15:11:53 [URL] [DELETE] :
In Reply to: loose lift mount on 9n leaks like a mother posted by Dan Chisler on June 01, 2017 at 13:21:41:
Remove,,lighten all that you can from the trumpets because these are heavy.You can remove the left (sitting on the seat)trumpet with the axel left inside if you have a way to hoist and hold it,,,you can hurt yourself BAD trying to do this by hand.While you tighten the left side you can reach through and tighten the other side without it's removal.Be sure to block and secure the right side so it won't roll or tip.You could leave the rightside tire on for this.There is a special way to replace the trumpet gasket.Others may chime in to help.
