Re: loose lift mount on 9n leaks like a mother
Posted by Charles (N.C.) on June 01, 2017 at 16:50:49 [URL] [DELETE] :
In Reply to: Re: loose lift mount on 9n leaks like a mother posted by Dan Chisler on June 01, 2017 at 15:53:24:
Left side tire remove or you might wind up in the hospitol.Leaving the axel inside the trumpet causes a lot of weight too but if you have a helper (friend,hoist etc.)things go better.To tighten the lower link support shaft yes you will have to remove the pin from the castlenut and yes put it back,,both sides.Now you are working with heavy parts so make a plan.A gasket should be used.My choice.These go on (1)way only.Now,,,,,do you have the I&T,FO4 Ford N Repair Manual? "GET IT".
