Re: loose lift mount on 9n leaks like a mother
Posted by Dan Chisler on June 01, 2017 at 20:33:06 [URL] [DELETE] :
In Reply to: Re: loose lift mount on 9n leaks like a mother posted by Charles (N.C.) on June 01, 2017 at 16:50:49:
Okay if a gasket is to be used then the trumpet must come all the way off i would assume ...Yes i have every repair manual made for the tractors . It looks like the tractor will have to go into waiting mode for a while . until i finish the clutch replace job in the dozer and i get the shop building built this year or next . then i can set it up on blocks inside and do the job correctly along with the transmission bearing replace job . Maybe i can find a Mobil tractor mechanic that wants to make some money .Do they exist ? Thanks for the response Charles I really appreciate it .
