Re: loose lift mount on 9n leaks like a mother
Posted by Dan Chisler on June 02, 2017 at 12:30:39 [URL] [DELETE] :
In Reply to: Re: loose lift mount on 9n leaks like a mother posted by Ed Gooding (VA) on June 02, 2017 at 10:59:22:
Ed Thanks so much for the great pictures i am saving them .I see the one nut to tighten how do i tighten the other one ? I don't even see it in the picture .Both are loose and just turn when you turn them . I have put pressure on the lift arm to bind the axle pin then try to tighten but it still turned. I didn't try an impact wrench .slap tork seemed to help but still loose.the nut in the picture I am assumeing is the smaller of the two fasteners not the axle is that correct ?
What is that load leveler ? a tool store item ?
