Re: loose lift mount on 9n leaks like a mother
Posted by Dan Chisler on June 04, 2017 at 11:21:24 [URL] [DELETE] :
In Reply to: Re: loose lift mount on 9n leaks like a mother posted by Farmer Brown on June 03, 2017 at 19:43:24:
Wow that is an interesting tid bit . Now how much trauma is it to get the pto shaft out ? Does it come out easy once the back 4 bolts are removed ?This is what I ws hopeing to find out some short cut .Maybe a cotter pin could be finessed in as well . Ford probably did not like the chance of that nut getting caught up in the ring and pinyon .I am going to study on that . Many thanks farmer Brown .I discovered the leak after reading one of the manuals warning not to ever loosen those nuts or you may get a bad grease leak . I thought it leaking from the muffler mounting bracket i installed .Then noticed how loose that mount was.
