Re: Oil pump pickup tube
Posted by ZANE on June 04, 2017 at 21:28:10 [URL] [DELETE] :
In Reply to: Oil pump pickup tube posted by Bob TX on June 04, 2017 at 20:57:43:
It would be best to sit the pan down on the block with the block upside down so that you can determine if the pickup tube cup is centered over the drain hole and almost touching when the plug is installed.
Zane
