Re: loose lift mount on 9n leaks like a mother
Posted by Farmer Brown on June 06, 2017 at 06:25:19 [URL] [DELETE] :
In Reply to: Re: loose lift mount on 9n leaks like a mother posted by Dan Chisler on June 04, 2017 at 11:21:24:
Very easy to remove pto shaft. Just need a new gasket and park tractor nose down in ditch so hydraulic fluid stays in or you can just allow it to drain in clean pan to reuse. It just pulls out, provided it is not twisted.
