Re: Hook up to pull ford tractors. Lost my help.
Posted by Den N Ms on June 08, 2017 at 09:11:14 [URL] [DELETE] :
In Reply to: Hook up to pull ford tractors. Lost my help. posted by Wayne N ind. on June 05, 2017 at 18:50:04:
Wayne,Make a lift that goes on the 3 point hitch,with a pivot bar that goes under the front axle with a U that will go up to catch the axle on each side,front side of the U taller to hit the axle front and line up the pivot bar.Then just lift enough to put up pressure to keep the pivot bar in place and move them around without having to get off the tow tractor. You won't have to lift the tractor front off the ground to move one that way,forward or backwards with tires and wheels on them.
