Re: Dearborn 10-8 Plow
Posted by Tim Daley(MI) on June 08, 2017 at 17:49:15 [URL] [DELETE] :
In Reply to: Dearborn 10-8 Plow posted by Dennis on June 08, 2017 at 17:43:39:
Dennis-
Heed this warning: the 12" plows are really not made anymore, especially Ford-Ferguson and Dearborn. The 10-8 Prior Model especially has no parts available unless someone has them on a shelf. The later Dearborn Economy Plows are much better anyway, with the 10-152 Model being the 12" one, but still, parts are rare as hens teeth. Where did you get the p/n 10-142? My book has no plows in the 140 range. Better check too to see if your Kubby will connect a Category 1 plow like a Dearborn. A lot of newer models won't pull a plow. If it will you can try just a 14" or 16" one bottom plow especially for just two acres. After you plow, then what? The usual procedure is to disc harrow...
