Re: 52 8N radiator thermostat
Posted by Bruce (VA) on June 09, 2017 at 19:39:17 [URL] [DELETE] :
In Reply to: 52 8N radiator thermostat posted by Scott McKinnon on June 09, 2017 at 19:08:25:
" he does not recommend using a thermostat in southeastern North Carolina climate on my 8N. "
That's ridiculous.
The climate has nothing to do with the need for a t-stat. The t-stat regulates the temperature of the engine. It allows the engine to quickly get to optimum operating temp & then keeps it there.
As tight as he was, Henry started putting t-stats in cars in 1933.
For more info on why a t-stat is important for your tractor's health, see tip # 25 at the link.
If you want to use a 180* t-stat (which I use on all 4 of my 8N's) try A&I part # A-11C15, Gates 33108, Beck/Arnley part # 143-0024, Auto Zone part #
3518 or NAPA part number THM 184 for 180* in hose t-stats.
The car parts store folks are helpless w/o vehicle make/model/year info.
Some can/will actually search on the number & cross reference, but more often than not, you will just get a dumb look. HINT: find a clerk near the age of your tractor..... ;) Try telling them that the t-stat is for your
1977 Renault R12 1.6L L4.
All of my 180* t-stats are A&I A-11C15's or AZ-3518's. They are a very tight fit in an N hose, but they will fit. I've never used the Gates, Beck/Arnley or NAPA t-stats so I can't help you w/ anything there but the part numbers.
All that being said.....if you do not consistently run the tractor to operating temp, you will get condensation & sludge as a result.
http://www.rockauto.com/catalog/moreinfo.php?pk=2582642&cc=1264609
https://www.napaonline.com/en/search?text=1977+renault+thermostat&isApplicat
ion=true&isPromo=0&referer=vehicleAdd
http://www.autozone.com/cooling-heating-and-climate-control/thermostat/dural
ast-thermostat/701254_0_1632_93208
