Re: 8N Lift
Posted by Ncorrigible on June 10, 2017 at 18:30:39 [URL] [DELETE] :
In Reply to: 8N Lift posted by mthomas on June 06, 2017 at 16:39:57:
I do not know where you live and whether or not your last winter was typical or atypical. In Minnesota anything denser than Ford spec 134D will be very slow at winter temps. Price and performance, I like Walmart Super Tech Tractot Hy draulic and Transmission. It works, it is not expensive, and it will be at your door 3 days after you order. You may want to order a bunch ( as in 6 - 12 ) of the big drain gaskets for oil / transmission / hydraulics. You will go through 3 each total oil change. Doing the rear always start with the small pipe plug in the differential. Failure to do so will make the reasoning obvious.
