Re: Ford Industrial 172/192 Woes - Running Smooth Smoking
Posted by steveVa on June 11, 2017 at 10:42:51 [URL] [DELETE] :
In Reply to: Ford Industrial 172/192 Woes - Running Smooth Smoking posted by Jon Rhee ( RI) on June 11, 2017 at 08:37:05:
New valve seals wouldn't hurt. After all that is what they are there for. But if you have some stuck oil rings it will still smoke. But they too may loosen up if you run it a bit and work it. How much have you run it? It could take awhile to get all the oil out of the system especially if you had oil dripping out of the exhaust. I would run it a while and see if the smoke don't clear up. Good compression is usually a good sign. But 165 is not exactly high...
