Water pump?
Posted by Tom on June 11, 2017 at 12:45:56 [URL] [DELETE] :
8n is overheating. Suspect water pump? When running and I look in the radiator I don't see flow as much as agitation from engine vibration. Doesn't feel like there is a thermostat installed when I squeeze the top hose so I'm thinking it may be the water pump.
Any other indicators or things I should look for?
If I do pull the water pump, there is an oil line blocking access to one of the bolt heads. How many bolts and where are they? Any other tips on pulling the water pump?
Can't find a YouTube on this procedure.
Thanks for any help\advice! Not really experienced at this kind of thing TBH.
