Re: Water pump?
Posted by 36 coupe on June 11, 2017 at 15:09:33 [URL] [DELETE] :
In Reply to: Re: Water pump? posted by BlasterStumps on June 11, 2017 at 12:59:45:
Check the top tank temperature with a meat thermometer .Prove that you dont have thermostat in the top hose.Cast iron pump impellors can lose their fins to rust.Plastic impellors can split and fail to turn with the shaft.If all that fails pull the radiator and have it shop cleaned.
