Re: Water pump?
Posted by 36 coupe on June 14, 2017 at 04:28:07 [URL] [DELETE] :
In Reply to: Re: Water pump? posted by R Geiger on June 11, 2017 at 13:06:12:
A water pump can have all the fins rusted away on the impellor.A plastic impellor can split and fail to turn with the shaft.A worn belt can slip in the pulley.Leaking or worn shaft wont stop pump from moving water.I know an engine can over heat if a thermostat is stuck open or missing.
