Re: Ford Industrial 172/192 Woes - Running Smooth Smoking
Posted by 36 coupe on June 14, 2017 at 04:37:51 [URL] [DELETE] :
In Reply to: Re: Ford Industrial 172/192 Woes - Running Smooth Smoking posted by Jon Rhee (RI) on June 12, 2017 at 18:52:09:
MMO has to spend some time in the engine to be effective.I have seen smoke reduce in 3 hours run time.Top rings are usually stuck on oil pumpers.Milling an OHV engine head reduces valve clearance.You must check valve clearance.I checked new engines as part of dealer prep on new cars.I found some tight valves on new engines.
