Re: Ford Industrial 172/192 Woes - Running Smooth Smoking
Posted by Jon Rhee (RI) on June 14, 2017 at 06:40:14 [URL] [DELETE] :
In Reply to: Re: Ford Industrial 172/192 Woes - Running Smooth Smoking posted by 36 coupe on June 14, 2017 at 04:37:51:
I've let the MMO sit on the pistons several times now. Its working its way down past the rings on a couple of cylinders over an hour or two. The other 2 it stays puddled. Not sure which is the better condition since its thin.
I did adjust valve clearance after the head was planed. Now looking at my valves, the exhaust valves mating surface is pitted. I was going to lap them but the manual only discusses grinding the seats and valves, or replacing the seats and or valves. Is lapping not an option?
