Re: Ford Industrial 172/192 Woes - Running Smooth Smoking
Posted by TheOldHokie on June 15, 2017 at 13:04:52 [URL] [DELETE] :
In Reply to: Re: Ford Industrial 172/192 Woes - Running Smooth Smoking posted by Jon Rhee(RI) on June 15, 2017 at 12:28:38:
IMO $115 for new springs, valves, and guides plus reasonable labor charges to cut the seats and install the guides is well worth the results. I also agree with your machinist - .004 stem clearance is pretty loose - especially on an engine that apparently does not have valve stem seals. If he can fit seals to those guides I would probably do that as well.
TOH
