Re: Spring Tine Cultivator.....parts needed....
Posted by Tim Daley(MI) on June 15, 2017 at 13:58:32 [URL] [DELETE] :
In Reply to: Spring Tine Cultivator.....parts needed.... posted by Dead Eye Dave on June 15, 2017 at 10:50:31:
Well, first the good news, if it is a Model SKO-20, it is a FERGUSON-SHERMAN, if it is a 13-2, it is a Dearborn, but nevertheless, parts are interchangeable. The bad news is these implements are no longer serviced, meaning they no longer make parts for them. You can try Scott Deppen in Halifax, PA, formerly Sweigard Bros, and he advertises parts on the ADS forum or look hom up in the LINKS. He may have some used parts for you. Next alternative is to find a used implement and swap out parts with it. Lastly, you can get new parts for cultivators AG Supply, et al but you will have to plan on doing some grinding and custom fitting to get them to work.
TPD
