Re: Brakes 52 8N
Posted by Jim In Montana on June 16, 2017 at 05:02:46 [URL] [DELETE] :
In Reply to: Re: Brakes 52 8N posted by Tim Daley(MI) on June 10, 2017 at 08:05:17:
Thank you Tim for the help. this is quite good. I was thinking the adjuster was a wheel, with little teeth on it, and you turned it with a brake spoon, or screwdriver. i see now, the adjuster is on the opposite of the plate. Looks like a square that i may be able to turn.
betting the darn things are probably frozen, as i am not sure it has ever been adjusted.
SO, on to the garage, with tools in hand, and get to work.
Thank you again,
Jim
