Re: 8N missing under load
Posted by Bruce (VA) on June 16, 2017 at 13:12:29 [URL] [DELETE] :
In Reply to: 8N missing under load posted by Tom8n396936 on June 16, 2017 at 12:20:28:
When is the last time you replaced the points, plugs, condenser rotor & cap and set the timing? A rebuilt motor stills needs a tune-up.
Get out your timing light & check to see if the timing is advancing.
See tip # 14 at the link.
