Re: 8N missing under load
Posted by Rustyal on June 16, 2017 at 15:15:00 [URL] [DELETE] :
In Reply to: 8N missing under load posted by Tom8n396936 on June 16, 2017 at 12:20:28:
Check the points, plugs and timing. Then you may want to look at the governor as it kicks in when the tractor bogs. I'm thinking the hay equipment could be to much for your tractor. My hay rake is to big for an n.
