Re: 2n hydraulic lift
Posted by Rustyal on June 18, 2017 at 11:34:59 [URL] [DELETE] :
In Reply to: 2n hydraulic lift posted by cage on June 18, 2017 at 10:11:24:
The valve is stuck or not connected. You can move the control lever and the valve will not move. It can be fixed from the side cover. You can replace the valve. Or if your cheap just take it out and knock the rust off.
