2n compression
Posted by William S Phillips on July 16, 2017 at 15:38:04 [URL] [DELETE] :
I have a 2n that is troubling me, I have done all the following. new fuel petcock, new carb and steel line, the tractor is converted to 12v and electronic ignition. I took a compression reading and it is 100psi on all 4 cyl. it will fire up every now and then and runs great, let it sit and it will not refire, after cranking fuel will come out the intake till it levels off with the float, also have confirmed good spark, book says 125 psi but i would think 100psi is still enough to draw the fuel up into the intake, I see the carb they put on it is a tsx 241B. any thoughts? Thanks Bill
