Re: New 8n 6 volt charging problems
Posted by steveVa on July 20, 2017 at 02:58:51 [URL] [DELETE] :
In Reply to: New 8n 6 volt charging problems posted by dave#1 on July 19, 2017 at 22:17:06:
I think you meant to say side mount dist. If the battery is fully charged it wont show much charging. Run the lights a few minutes and then turn them off. Then it should show charge for a few minutes. Charging issues are usually a connection, the voltage regulator, or the brushes in the generator. Check the voltage at the battery before and after you run it with the lights on for a few minutes with the tractor turned off. If not cha4ging, tap the VR with wood block or something while it is running qnd see if amp ga jumps. Same thing to the generator.. Nice looking tractorl.
