Re: 8n not running very well
Posted by Bruce (VA) on August 01, 2017 at 15:18:33 [URL] [DELETE] :
In Reply to: 8n not running very well posted by Dethomas on August 01, 2017 at 14:58:14:
Don't even think about buying a new carb if you have an oem m/s carb on the tractor. You have at least worn throttle bushings. If some of the folks around here that rebuild carbs are busy, try a local rebuild shop. Or I can send you the address of the one I use.
