Re: Post Hole Auger on an 8N
Posted by John in Mich on August 02, 2017 at 09:38:26 [URL] [DELETE] :
In Reply to: Post Hole Auger on an 8N posted by mthomas on August 01, 2017 at 23:17:52:
I have used my phd on both the 8N and the NAA. The NAA works better because of the live hydraulics (you can clutch/stop the pto and still lift the auger if needed). I try to watch the feed rate and with my hand on the hydraulic lever ready to jerk it upwards. When it grabs something it can sink fast. I have had to pipe wrench out on both roots and rocks. Usually, a couple of turns will allow the hydraulics to lift the auger out. Be safe, turn the tractor off if you have to use the wrench. Exhaust fumes.
