Re: Need full choke to run
Posted by carl nny on August 02, 2017 at 15:29:01 [URL] [DELETE] :
In Reply to: Re: Need full choke to run posted by Neal on August 02, 2017 at 14:56:35:
I'll start by saying that I'm not an expert.I had the same problem under the same circumstances last year and can only say what my problem was. With running it very low on gas I stirred up sediment in the bottom of the tank. I had to pull the tank and clean it and all three filters. After that it ran good again just like before. I learned that running the tank very low is a bad thing. I will now shut it off and walk back and get more gas before I open the shut-off valve more than two turns. Like I said in the beginning, JMHO.. That was "MY" problem but it could be all or any of the responses that the other guys have said also.
carl nny
