Re: Runs fine then dies after 10-15 mins
Posted by Bruce (VA) on August 02, 2017 at 17:37:16 [URL] [DELETE] :
In Reply to: Re: Runs fine then dies after 10-15 mins posted by fuesselfc on August 02, 2017 at 16:54:20:
Not really checking fuel pressure as it does not have a fuel pump. You're checking flow.
And if you ask your buddy to check spark gap he will pull the spark plugs! You're checking spark intensity, not gap. It's the distance the spark jumps at the plug that gives you the info you want. It takes about 22kv to jump in the open air. Remember, its 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 22kv to fire the plugs when the engine is running.
