Re: 9n won't start resolution now it will start .
Posted by Dan Chisler on August 05, 2017 at 10:26:04 [URL] [DELETE] :
In Reply to: Re: 9n won't start resolution now it will start . posted by mhb@ufe on August 05, 2017 at 07:02:50:
Yes I suppose so . It is pretty easy to get at the starter on a tractor I also wanted to see if things were okay with the gears . The starter ring does have sharp edges . If i ever have the ring gear exposed i would clean up the ring gear with a small file.
