Re: losing antifreeze mix
Posted by poderac on August 05, 2017 at 21:27:12 [URL] [DELETE] :
In Reply to: losing antifreeze mix posted by Ted Pellerin on August 05, 2017 at 16:31:28:
If there is no coolant coming out and onto the ground, it is most likely a blown head gasket. Check the exhaust pipe after a couple of minutes running and note if it's just water condensate or if it is antifreeze.
