Re: Alternator replacement
Posted by Bob in KS on August 06, 2017 at 08:30:02 [URL] [DELETE] :
In Reply to: Alternator replacement posted by Roger on August 06, 2017 at 08:19:36:
Yes. With plug at top of alternator for reference, loop the #2 (right side) pin down to the output stud.
Connect the #1 pin through a diode, resistor or lamp to the output of ignition switch.
Device in the line is to prevent the engine from continuing to run when switch is turned off.
