Re: alignment won't hold
Posted by fritzk on August 07, 2017 at 13:04:01 [URL] [DELETE] :
In Reply to: Re: alignment won't hold posted by Bruce(OR) on August 07, 2017 at 09:54:16:
thank you.
It is my fondest dream that you are correct.
Soooo much easier to replace than steering components.
curious how you would explain that; 1. the bottom portion didn't just fall onto the ground when I jacked the front end up with the tires still attached (added weight) and 2. that the entire assembly from stem to stern and right to left seemed, that is, seemed to function when I had the front end blocked up off the ground and thought I had the steering column and sectors 'tuned'( re-meshed, re-centered) .
In any event, thank you for your response and your consideration.
