Re: NAA FORD ROCKING AMP METER
Posted by Tim Daley(MI) on August 09, 2017 at 15:20:02 [URL] [DELETE] :
In Reply to: NAA FORD ROCKING AMP METER posted by Norman Picard on August 09, 2017 at 15:06:53:
Norman-
I am assuming you mean the ammeter needle is bouncing back and forth. It could be a few issues: Loose belt, bad wiring/short, bad voltage regulator, weak battery, or more. You may be better off taking the whole generator, the voltage regulator, and the ammeter, to your trusty local starter/alternator shop -the one who knows all about these old 6-volt devices as they can bench test all, tweak if needed or rebuild if needed. You do know these old machines were originally wired as 6-volt/positive ground systems right? Have you verified what you have is all correct according to JMOR's Wiring Pictograms? SEE HERE (click on LINK)
