Re: 8-N hydro question
Posted by TheOldHokie on August 09, 2017 at 20:06:16 [URL] [DELETE] :
In Reply to: Re: 8-N hydro question posted by dave#1 on August 09, 2017 at 17:43:36:
I use a belt drive. The shaft drive will work fine. Regardless of how you drive the pump just remember the flow to the test port cannot exceed ~3 GPM or you will overwhelm the OEM valving. That is the reason for the flow divider....
TOH
