Re: 8n lift is slow to lower
Posted by Model660 on August 16, 2017 at 16:55:21 [URL] [DELETE] :
In Reply to: Re: 8n lift is slow to lower posted by Bruce (VA) on August 15, 2017 at 21:39:38:
New cylinder, piston , linkage tightened up, new follower pin. The pump was took apart and checked and found to be in good shape. I didn't take the control valve out to check it because the lift linkage was so worn , I figured that was the problem. Put it back together and it worked great. Six months pass and the lift was doing strange things, keeps going up even when you stop raising the handle in position . Draft works fine. I worked the control valve by hand on the pump and position works good now,just is real slow going down
