Re: 8n lift is slow to lower
Posted by Bruce (VA) on August 17, 2017 at 08:34:14 [URL] [DELETE] :
In Reply to: Re: 8n lift is slow to lower posted by Model660 on August 16, 2017 at 16:58:02:
Put a heavy implement, like a disc , on it & see what happens.
The oil isn't an issue unless it's really cold outside. If you used the TSC oil that says it meets the 134 spec, you won't even have that problem.
