Re: 8n lift is slow to lower
Posted by JMOR on August 18, 2017 at 04:43:42 [URL] [DELETE] :
In Reply to: Re: 8n lift is slow to lower posted by Model660 on August 17, 2017 at 16:53:45:
You may be able to remove lowering (exh) valve with pump installed, but even if possible, the working space will make it difficult, plus not easy to be sure ports in bushing are clear. Pump can be dropped without top cover removal as I have done that.
