Re: Starter and timing problems
Posted by clayton ingmire on August 18, 2017 at 17:32:26 [URL] [DELETE] :
In Reply to: Starter and timing problems posted by Tinkerer60 on August 18, 2017 at 12:28:56:
like bruce said ignition timing the exact point the spark plug fires in relationship to crankshaft rotation is completely different from point gap that you are trying to set even through when the points open this is when the coil discharges its built up voltage and fires the plug your problem is the crankshaft has not turned close enough to top dead center and the plug fires and drives the piston backwards while the starter is still engaged
