Re: Sherman Hi-Torque Head
Posted by 36 coupe on August 19, 2017 at 07:59:07 [URL] [DELETE] :
In Reply to: Re: Sherman Hi-Torque Head posted by Farmer Dan on August 13, 2017 at 21:41:32:
Ford started using aluminum heads on the V8 in 1934.There were problems getting them off a few years later.The aluminum seized on the steel studs.I would not put an aluminum head on my tractor.Ford quit using aluminum heads in 1936.I used cast iron high compression heads on the 59A engine I put in the 36 coupe in the 50S.
