Re: 8n lift is slow to lower
Posted by Model 660 on August 19, 2017 at 15:49:48 [URL] [DELETE] :
In Reply to: Re: 8n lift is slow to lower posted by JMOR on August 18, 2017 at 04:43:42:
I pulled the lift cover to check linkage and found some of that to be sloppy. Got that tightened up.and also removed the raise and lower valves. Does the lower valve have a spring behind it? This one didn't . I stretched the spring on the raise valve a little. To help push it back to neutral when you set the handle in position control. Hopefully won't have to drop pump. Even the pivot pin between the raise and lower valves was sloppy. No sense in a 70 year old tractor being this worn out 🙂
