Re: thermostat install direction
Posted by tim sullivan on August 23, 2017 at 09:53:26 [URL] [DELETE] :
In Reply to: Re: thermostat install direction posted by Tim Daley(MI) on August 22, 2017 at 17:56:58:
Hi Tim, does not look like that one, it has a flat sheet bi-metal wound spring inside the tube on one end, opposite the tube direction. At the other end inside the tube are 2 clam shell looking parts that are together when cold, and split open in the center when hot, these clam shell parts look cast, not sheet brass. will try to take a picture when i can get near the tractor in a couple of weeks. It's a 48 8N
