Re: idle mixture trouble
Posted by clayton ingmire on August 30, 2017 at 23:07:16 [URL] [DELETE] :
In Reply to: Re: idle mixture trouble posted by R Geiger on August 30, 2017 at 21:37:36:
lean it back out till it runs rough get a can of carb clean and carefully spray around carb if you hit the right spot it will smooth out also could be bad intake rotted through from exhaust side to intake side Chinese manifolds had this casting problem
