Re: Need help finding distributor parts
Posted by Farmer Dan on September 04, 2017 at 11:48:07 [URL] [DELETE] :
In Reply to: Need help finding distributor parts posted by Farmer Dan on September 04, 2017 at 11:43:32:
After looking at the picture I guess I should explain.
The brass screw at the top that the coil spring contacts is missing.
The nylon/plastic insulator is also missing.
The eccentric screw that you adjust the points with is also missing. I know the screw is "braded" but if I can get a new or good one I can replace it and brad it back in. Easier than buying a new plate.
