Re: Carb still drips fuel
Posted by Tim Daley(MI) on September 14, 2017 at 05:00:42 [URL] [DELETE] :
In Reply to: Re: Carb still drips fuel posted by NTP on September 13, 2017 at 07:10:34:
I'd leave the float gage dimension as it is set now at 1/4". I don't think that is the root cause of the problem. All parts wear, and ten years between carb rebuilds is awesome, but not uncommon. I've worked on probably hundreds of the M/S carbs and have received some that looked like they were never rebuilt after they left the Borg-Warner factory. When you rebuilt your carb, did you install the new float seat, gasket, and needle valve? Some new needle valves have a rubber tip and seem to wear faster than solid brass ones.
http://www.ntractorclub.com/howtos/pdfs/Carburetor-Overhaul.pdf
