Re: '63 tug not starting
Posted by Tim Daley(MI) on September 18, 2017 at 10:18:07 [URL] [DELETE] :
In Reply to: '63 tug not starting posted by doug on September 18, 2017 at 08:46:06:
Fuel Sediment Bulb isn't electric -there's nothing to get hot ... ; > ) but understand what your trying to say. Was it working before you changed it? Did you verify you had good fuel flow after the change and before turning over engine? Finally, is the battery 6-volt or 12 volt and is the wiring correct?
