Re: wires
Posted by Ultradog MN on September 22, 2017 at 07:44:11 [URL] [DELETE] :
In Reply to: wires posted by Larry on September 22, 2017 at 06:50:50:
I can't get your picture to come up.
Keep getting an error mssg.
But the two wires coming out of the top civer are for your neutral safety switch.
The small stick (high/low)
Is supposed to be in neutral before the engine will turn over with the key.
They are kind of finicky so a lot of people just bypass them and hook the two wires that come down from the dash together which defeats the nss.
Mine would rarely work properly so I disconnected it. Had to pinch the two wires from under the dash together to make it start. Worked fine as no one would know that. Not bad on a diesel but on a gasser where you have to fiddle with the choke you don't have enough hands to do all 3 things at the same time.
