Re: Starter Issue
Posted by Bruce(VA) on September 22, 2017 at 14:58:08 [URL] [DELETE] :
In Reply to: Starter Issue posted by TarHeel Dick on September 22, 2017 at 12:00:34:
" Battery test at 6.35 volts."
A voltage test will tell you if you have a bad battery.......but not if you have a good battery.
You can do a voltage drop test yourself. Or you can use a hydrometer (tip # 49) or a load tester if you have one.
Or take it to an auto parts store for a free load test.
