Re: starter flywheel problem.
Posted by mhb@ufe on September 25, 2017 at 15:20:19 [URL] [DELETE] :
In Reply to: starter flywheel problem. posted by Tinkerer60 on September 25, 2017 at 12:42:31:
It sure sounds like you have a bad ring gear to me. When you shut the engine off the flywheel will stop very close to one of two locations every time do to pistons coming up on compression as it is winding down. Turning the engine manually gets it away from the worn teeth. When checking the ring gear teeth you need it to be in one of those two locations and check the back side of the ring gear teeth as that is where they will wear.
Mark
