Re: Ongoing Noise & 9N Footboards
Posted by farmer Dan(OR) Chisler on September 28, 2017 at 05:59:31 [URL] [DELETE] :
In Reply to: Re: Ongoing Noise & 9N Footboards posted by Farmer Dan(MI) on September 28, 2017 at 05:58:02:
Rite now i am not using oil . It leaks out threw the lift arm supports . I have some spare parts and when i can get a good place to work on the rig i will try and deal with the problem threw the pto hole .Some one mentioned he was able to hold the nut and tighten the shaft . I wonder how tough it will be to deal with the cotter pin from with in ?
Where do you get 90 weight mineral oil ? My noise sounds like a ring and pinyon noise and i picked up a nice R & P matched set .In the event that is what it needs .The noise is pretty loud so i don,t run it very much . Just to move it out of the way from time to time. I was using 90 weight gear oil before the major leak started up.
